continental_drift wrote:as far as hubcentric rings, I'd just buy hubcentric spacers
The hubcentric ring centers an aftermarket or non-OE wheel to the cars hub. Hub centric spacers basically have a hub machined into them that should be the same diameter as your vehicle's existing hub. If you were to get hubcentric spacers then you could use your existing hubcentric rings on it. Another nice thing about hub centric spacers (slip on type) is that they also fit perfectly around the OE hub unlike cheap universal ebay ones. Keep in mind that quality hubcentric spacers arn't cheap, but after using cheap ebay ones, I think it's worth the extra cash.
On my s14 with a 5mm spacer I could not use my hub centric rings because only about 2mm of the hub was exposed. I could mount my wheels with them in but there was not enough hub engagement for the rings to work so I got high speed vibrations. I don't promote the use of spacers, but I really liked my 16x8 3 piece wheels and they did not clear my z calipers so I made them fit.
FYI: H&R spacers are not hub centric at 5mm thickness because the spacer needs to be thicker than the OE hub to have a machined hub
I am not a fitmet master like some people on this forum, but I know you could find the answer about clearence if you searched it. It would also help if you posted your wheel width.
