do u need to oil change at dealer to maintain warrentee?
LegendRacer
i want to get my oil changed somewhere else...i hate stealerships and there bs
will they cut my warrentee cause i dont go to them for oil changes?
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
no, but you should keep receipts everytime you buy oil filter, oil, etc. A pain in the ***, I haven't kept mine .... crossing my fingers though
Team STILLEN
Car: 2004 G35 Coupe
Absolutely not. You are free to get your oil changed, or any maintenance at anywhere you see fit, but obviously on the maintenance end, taking advantage of that warranty is where it's at.
It's always a good idea to keep all of your maintenance records, especially when the re-sale factor comes out years from now.. it's a huge selling point when someone walks up with a giant folder of meticulous records..
LegendRacer
Josh@Stillen wrote:Absolutely not. You are free to get your oil changed, or any maintenance at anywhere you see fit, but obviously on the maintenance end, taking advantage of that warranty is where it's at.
good point!
anyone have suggestions of what type of oil i should fill into it? i want the best oil. I am a newbie at what type of oil that is best. I heard synthetic is the best? what brand? i have a 3.5
niztec
Car: 2008 AlTIMA COUPE
if its your first oil change i would recommend that you use regular oil first, then maybe the second oil change you can use synthetic. make sure you change the filter every time too
Team STILLEN
Car: 2004 G35 Coupe
Absolutely agree with niztec, definitely roll traditional oil for the first 1 or 2 oil changes, and then move to synthetic. Sounds scary, but a new engine is going to work out it's own internal weaknesses, and may end up with contaminants in the oil, so regular shorter intervals is preferred at first, and then you can relax a bit with the timing on future changes.
IMHO, 7,500 miles is fine on most broken-in engines, but 2,500-3,000 for the first couple is good protection. 3,500 miles from beginning to end is overkill, but if you have the $$ and enjoy that warm cozy feeling knowing you did all you could do on the maintenance end, absolutely can't hurt.
For you older engine folks, switching to synthetic late in the game could open up some issues you weren't prepared for. Synthetic oil is, by design, thinner, and is not recommended for switching on high mileage engines, despite the oil's inherent benefits. It's very possible for synthetic to slip past older worn out seals, and cause leaks where existing oils didn't.
windhaven
Car: 2008 Nissan Altima Coupe 3.5 CVT Winter Frost/Blond Full Load
FYI, i've done 2 changes at 2K intervals, btw - You should have seen the crap that came out of the first one. Switched to the Synthetic at 6,500. By the 3rd set of oil (Original + 2 regular oil changes) I see very little debris.
After one more change, i'm moving to the recommended cycle unless there is real hard driving involved.
-- wind
Idok
Car: 2007 Altima 2.5 S/2008 2.5 coupe
You could also scan all your receipts and keep electronic versions for back up, that way when you sell it you could furnish a CD for all maintenance done.
As far as oil change interval I agree w/ Josh at Stillen. My last oil change went out to 6000 miles using Mobil one and Napa gold filter. Used oil analysis said the wear numbers looked good and no significant dilution or viscosity change. The lab said I could extend the change interval a little longer if I wanted.I will probably keep it at every 6500 miles from this point on.
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
nissan service tries to scare you into bringing your car to them for service which in my opinion is a crock of sh*t.
nissan sends out a sh*tty letter trying to get you in and pay for their service by saying - verbatum
Dear _________Your vehicle is due for the service shown above, according to the guidelines of you manufac. warranty.
It's important that you follow the factory guideline for regular maintenance and have this service performed at an authorized service center at your earliest conveniece. Not doing so could affect your eligibility for warranty repair as indicated in your owner's manual.
Call your nearest dealer and we'll take care of this right away.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
08altima35 wrote:nissan service tries to scare you into bringing your car to them for service which in my opinion is a crock of sh*t.
Looking at your SEMA turbo Coupe, I think your ride would be a prime canidate for the Magnason Moss Act.
Honestly Nissan, I wasn't aware that the turbo would blow up the motor...
08altima35
could you imagine. "here nissan techs. my ride needs service according to your threatening letter. i'd appreciate it if you would just work around the turbo and not touch anything that you don't know a damn thing about!"
and the sema foxmarketing coupe isn't mine. mine is just the one undergoing turbo developement right now. Wish i had that one too though.
Modified by 08altima35 at 5:51 PM 3/1/2008
LegendRacer
if i go for a regular oil change for my first oil change (i have 5500KM about 3800miles) what type of oil brand should i get? im going to Minit Lube since its open tomorrow (sunday) and its cheaper
but what oil BRAND is good? i wont cheap out a couple bucks for good oil
*yes im a newbie in oil changes and stuff, since i used to own a integra which i didnt give a **** about haha
johnny_d
i'm a noob too but oil is oil, people will have preferences on oil, a lot of people like Mobil 1, then there's that Royal Purple stuff that will burn a hole in your wallet. Most importanly, change it often, with the correct oil type 5W30
08altima35
i'm one of the mobil1 full syn fans. 3000 miles, 3 trips to the 1/8 drag strip, mostly city driving and my oil was still light gold in color. can't beat that.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
+1 for Mobil 1. They have been in the business for a long time. They know what they are doing with motor oil.
LegendRacer
hmmm mobil 1 it is then...
is all mobile1 synthetic? since you guys suggested to go with regular for the first or second oil changes?
and what series oil do u guys use (from mobil 1)?
08altima35
i buy filters at the dealership and oil wherever is cheapest in bulk and change my own and dispose at auto zone. 5w30 mobile 1 fully synthetic. go to the bank before you pay someone to change your oil with fully synthetic cause they charge alot.
adidas2go
I did my first oil change with part syntheic. The Mobile 1 7500 miles. My next oil change i will jump up to Full Synthetic. Mobile 1 15000 miles. Its a good stepping stone for your engine to adapt and break in to the oil. Conventional Oil, Synthetic Blend, and finally Fully Synthetic. When the time comes that you put fully synthetic in your car, you can consistently change it at 7500 miles with more fully synthetic. Without hurting your engine
windhaven
08altima35 wrote:i'm one of the mobil1 full syn fans. 3000 miles, 3 trips to the 1/8 drag strip, mostly city driving and my oil was still light gold in color. can't beat that.
Me too, Mobile One has done me good over the years.
-- Wind
