do they make turbos for automatic 350Z???
Nissan 350z / Nissan 370z general community discussion forum
gmoney350Z
Car: 06 nissan 350Z
i wanted to know if they make turbos for automatic 350Z...if so, who???...thank you!!!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
according to APS both their single and twin turbo kits fit but require an upgraded torque convertor to keep form killing your trans, I suspect most kits will fit but require the trans upgrade, just decide what kit fits you best then look up the manufactureer and find out if it'll fit before buying, also any respectable retailer should hbe happy to help you locate the kit that fits your best
gmoney350Z
Car: 06 nissan 350Z
yeah i just look at it and i think thats what imma do...thanks!!!
00selimited
Aside from the transmission upgrade, i would think the FMU/ECU will have to be done specifically for the auto model, since the timing setup is slightly different on auto's and i don't know if the FMU/ECU they supply will pull the timing accordingly on auto models.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Turbonetics @ TurboneticsInc.com has a single turbo kit for the manual and automatic Z that comes with everything and no need for an ECU upgrade, the package comes with instructions for having the stock computer reflashed. The kit increases 163hp from stock! Under $5000 on TurboKits.com
bizcotch
Car: 350z 240sx
rmezz13 wrote:Turbonetics @ TurboneticsInc.com has a single turbo kit for the manual and automatic Z that comes with everything and no need for an ECU upgrade, the package comes with instructions for having the stock computer reflashed. The kit increases 163hp from stock! Under $5000 on TurboKits.com
+1
gr1ml0ck
Dont you have to use the "manual shift" mode?
rmezz13
Not to my knowledge... email turbonetics... i never looked into it i have a manual.....
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
Like most people are saying you most likely will need the stillen valve job upgrade to keep it from blowing up the transmission.
Return to “350z / 370z Discussion”
