do they make spacers for the head to reduce CR?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
i'm thinking, since the SR also has casted pistons but they are running lower CR, it makes them alot friendlier to boost.
now i can't afford a entire engine rebuild esp since my engine still has perfect compression. now i want to run 20 psi and i know that if they make some kind of spacer for the head, it would be the cheapest and most effective way for me to up my boost reliablity.
anyone chime in on this?
KATwo40
Car: 1993 240sx KA-T
There's an area around the outer edge of the piston that comes closest to the edges of the combustion chamber on the head. This area is called the "quench" zone. It's sole purpose is to squish the intake charge toward the center of the combustion chamber, isolating it from the cylinder wall and ring area.
When you increase the distance between the piston and the head (via thicker headgasket, as you're considering), this quench area is adversely affected.
By opening the quench area, gases are allowed to hang around the rings, which creates hotspots in the combustion area. Hotspots are an advocate of detonation/pre-ignition.
Consequently, opening the quench area will create a knock-limited engine, meaning that MBT is not reached before knocking occurs. You might be successful in lowering the static CR, but you won't be able to achieve maximum torque before knocking.
In short, there's no better way to lower the static CR than either forged low compression pistons, or modifying the combustion chamber on the head, the latter being a second choice over the first.
Hope this information helps.
S14tat
Car: 2007 FX35
1994 Acura NSX
gotcha. but if i put lower compression pistons wouldn't that affect the quench area too? or its not as bad becasue the lower compression pistons are shaped differently with a deeper dish?
epokh
Car: 92 240 HB
92 240 Coupe
02 Sentra
No, it's not the same, because correctly designed pistons retain proper quench...the compression is lowered by "dishing" the center of the piston, without disturbing the outer quench area.
S14tat
Car: 2007 FX35
1994 Acura NSX
ic
KATwo40
epokh wrote:No, it's not the same, because correctly designed pistons retain proper quench...the compression is lowered by "dishing" the center of the piston, without disturbing the outer quench area.
Correct, sir!
sil80drifter
Car: 1990 240SX Hatch
Am I not getting this right, or has nobody ever heard of a thicker headgasket?
sil80
KATwo40
sil80drifter wrote:Am I not getting this right, or has nobody ever heard of a thicker headgasket?
sil80
Uh...that's what we've been discussing the entire time. Silly drifter!
