szh »
https://forums.nicoclub.com/szh-u149.html
Fri Sep 21, 2007 9:15 am
Andrew,
29k miles is way too low for rotor replacement - but if the width is truly that low below spec, then you need to get it done! Mine are now at over 53k miles and I have only had them turned once when the pads were last replaced. Normally, the OEM rotors tend to last between 2 to 3 pad changes ... given that my pads now seem to last quite a long time, I think that 2 pad changes will be the norm for me. I will check at the 60k mark soon enough.
Also, quite often, people mistake vibration as due to warped rotors and/or get talked into it at the dealers. Far more often (not always though), the issue is wheel or tire imbalance. Before cutting or replacing rotors due to "warping", I strongly recommend a good tire re-balance session (assuming that your tires are good ones!) on top-notch balancing equipment. Can make a world of a difference!
Finally, after you replace pads (and rotors), they MUST BE BROKEN IN CAREFULLY! This process - basically 10 hard slow-downs (don't come to a full stop! that causes the hot pads to sit on hot disks at one spot and spots the rotors) in a row from highway speeds - is needed to properly and evenly coat the rotor with pad material. After heating the pads in this way, drive some more miles - no braking - to cool the rotors and pads down before then driving normally.
Good brake technicians (a few at Frontier Infiniti in San Jose do it right!) know to get this done after the work.
Z
