Do S14 Se Rotors Fit Z32 N/a Rear Hubs?
lv180sx
Car: 180sx
also, can someone verify that R32 skyline rear hubs are the same as the Z32 N/A rear hubs? or are they the same as turbo Z32 hubs?
574-240sx
Car: Nissans, Toyotas, Subaru
I believe turbo Z hubs are bigger because of the larger axels. I'm using my stock S13 rotors drilled out to 5 lug on 300zx N/a hubs. So S14 se rotors should fit z32 n/a hubs no problem. I'm not sure if rear skyline hubs are the same as N/A or TT hubs. If I was to take a guess I would have to say they are the same as N/A hubs.
Modified by 574-240sx at 5:06 PM 9/6/2005
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
the z32 houses its drum ebrake inside the center rotor housing/hub thing. I doubt s14 rear rortors will fit.
cdlong
Car: '95 240sx
SE rotors fit on NA hubs without the parking brake, they are seperate parts so you can use the hub but not the brakes. i know this for a fact.
not sure on the r32 hub thing.
