Sure, thanks.jrb92se wrote:i have an r33 rb25det s2 in my 240 and i recently had the ac hooked up with custom ac lines made by zfever (bad) using lines and a compressor from a 350z. i had the original ac compressor from the r33 but it was no good and they used what i was told was a z33 compressor. if you want ill get the info off the label on it.
Do 350z compressor work with rb25 or even fit with bracket?jrb92se wrote:i have an r33 rb25det s2 in my 240 and i recently had the ac hooked up with custom ac lines made by zfever (bad) using lines and a compressor from a 350z. i had the original ac compressor from the r33 but it was no good and they used what i was told was a z33 compressor. if you want ill get the info off the label on it.
