Do our VQs use normal oil or synthetic oil?
MattB
Car: 2001 Infiniti I30A
I was going through the records on my car that I got from Infiniti, and the car has documented oil changes every 3K at Infiniti dealers (good). But it occured to me that I have no idea whether to have the dealer change the oil with synthetic, normal, or blended oil the next time it's in. I suppose there could only be benefits from switching to synthetic (only have 67K on the car so it's not likely to develop leaks from a switch to synthetic), but on the flip side it's EXPENSIVE. What do our VQ30DE-Ks need?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
The dealer will not use synthetic unless you ask for it. I personally use Q full synthetic. It is more expensive, but I will pay the extra if it makes the car last a little longer.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
i have over 200,000 miles on my max and i still use Castrol GTX 5W-30. no synthetic whatsoever.
MaximA32
My '98 is just about to roll to 76k and I switched it to Mobil 1 synthetic the very first oil change I did. It's worth the extra money IMO. I also use factory Nissan oil filters.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
i use purolator pure one oil filter (PL14610) and just change the oil every 3,000 mi.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Take your own synthtetic oil, and M1 fliter from IoS and crush washer and the dealer may only charge you for labor.
I also envirolution my engines before the switch.
MattB
Well I called the dealer that did the last oil change on it (the dealer I bought it from) and they said they used a synthetic blend oil. Is it safe for me to go back to regular oil or go to synthetic or do I have to stay with the blend?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
when the blend is used you can go either way, unless i'm mistaken. it's once you go with full synthetic that theres no turning back
MattB
I guess I'll have to see what the price differential is between synthetic and blend the next time I'm in for an oil change.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
jltibbs wrote:i have over 200,000 miles on my max and i still use Castrol GTX 5W-30. no synthetic whatsoever.
IMO synthetic is overrated
A.Tech
Car: 1998 Nissan Maxima SE Black on Black 5-speed, and yes. I know my avatar is a Gen 5... lol
Best synthetic oil to get imo... is Mobil 1 Supersyn 5w30 for winter and 10w30 for summer... That is what I use with a M1 oil filter. ($55)
The owner before me had cheapo vavoline in it for a while... ugh... and I just used it for about 1000k and I changed it. Eventhough it is... expensive... It is better and last longer than non-synthetic oils and is more worth it. I just changed mine in oct and I have went 4k since then and I about about to change it once I hit around 6-7k. Eventhough they say you can do 9K with these oils I wouldn't for older cars llike ours with 100K plus on the engine because the oil gets dirty quick with all the racing/reving we do. haha...
And I have become to believe somehow that synthetic oil gets dirty faster and burns up more than normal oil. Could be just mine though, but after 3,500k my oil was about a quart down(No leaks) and the oil was black instead of a golden brown(what I am used too).
