elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Nov 27, 2013 4:50 am
I wouldn't think after 70k miles that the trans would have a lot of build-up. Normally on cars with 60-100k miles the trans fluid still looks pretty good. That's not to say that it doesn't need changed, I think after 60k miles it's time to change the fluid.
A mechanical "flush" can be done equivalently at home if you want to. You can buy the same cleaners that transmission flush machine uses.. However if you're not going to be doing this DIY style, then just take it to a shop for a fluid change.. It can't hurt! I don't think you have to go to the dealer per-se, however you'll want to be sure to get the J-matic fluid if you take it to an indy shop.
Diff fluid is also good to change as well...
