do js need valve lash done??? at a certain mileage
kccake
Car: i994 infiniti j30
do js need valve lash done??? i had one other import(sort of!!!) car a 92 taurus sho with the yamaha engine3.0l 24v dual ohc(blew her up LOL!!!)and it had the same noise i am hearing now(clicky noise coming around valve covers) in my j and it was valve lash so i bought the shim kit!!! and poof it was gone!!! so do the js need the same thing done at a certain mileage??? as i did not get a manual with my car!!!any help is appriciated thanks kevin
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The VGs have HLA so they shouldnt need valve jobs done.
Q45tech
Are you hearing the fuel injectors clacking? or dirty gummed up HLA use BG Quick Clean for Engines.
driverdriver
Car: NICO's longtime resident Canuck!!!
BG Quick clean isn't available up here due to environmental/clean air regulations. Go to Canadian Tire and use on of their bottles of Total Fuel Injector/System Cleaner. Its sold in tall silver bottle with red striping. Its around $12 (Canadian)/bottle. Follow the instructions.
For clacking hydraulics and lifters use CT's "Tune-up in a Can" or "Engine Restorer".
yodawill2000
Car: 94 Infiniti J30
Q45Tech , I have a injector leaking down after shut off,Would BG quickclean help with that ?
I did a round of Techron 2 weeks ago and was wondering if thats what caused it ..
elwesso
2007 BMW M Coupe
driverdriver wrote:BG Quick clean isn't available up here due to environmental/clean air regulations. Go to Canadian Tire and use on of their bottles of Total Fuel Injector/System Cleaner. Its sold in tall silver bottle with red striping. Its around $12 (Canadian)/bottle. Follow the instructions.
dont confuse BG 44k and quick clean! Quick clean is added to the crankcase!
Yoda, if you have an injector leaking down you must have a bad O ring somewhere.
yodawill2000
Hmm ,, I thought maybe the injector valve wasnt seating .. just an O ring would be a LOT cheaper.
yodawill2000
Anychance the tecron hosed the Orings up if thats the problem ?did the 1 bottle with 12 gallons routine just a few weeks ago.
Q45tech
The injectors get noisey after 60,000 miles doesn't hurt anything..........Techron is a detergent in a gasoline like carrier and doesn't affect o-rings
yodawill2000
So if the engine purrs like a cat when running , and a cylinder / cylinders flood after shut off , its probably an Oring issue ..Just trying to not buy an injector if I dont need too .Tight times here ..
