It was the rear amps only... if I recall correctly 91 & 92 model year. Bose did a courtesy rebuild of my fronts (I have 91 amps in my 90 - long story) due to the recall on the rears. Not sure if they're still doing that or not.infinitinut2 wrote:I seem to recall Bose/Infiniti warranting early Q's amps due to "fire danger", or some such. I recall sending mine to Bose, and them either repairing them, or sending me new ones. Quick R&R of them, too. Greatly improved the sound once new ones installed. Just wish I could remember if I did the R&R, or dealer!!! (Senior moment, I guess!)
Perhaps someone else recalls this issue.
So no noticable change (good or bad) by using a slightly different part? Notice any difference from the left to right? I suppose if these caps are just filtering caps on the power supply the difference would be very minor.texasoil wrote:........They were 820 uf@16VDC. We replaced them with 1000uF@25VDC, 95C temp.....
That guide is the pictures I took tonight but I can't get them to show up in my post.qsiguy wrote:I forgot about that guide on q45.org.
Thats interesting.mxr662 wrote:I removed the capacitors from one amp. They are 1000 uf 16volt.
Thanks for the picture posting help.anlasak wrote:These pics?
Here's the pdf for that page linked above -> http://www.edn.com/contents/images/56634.pdfQ45tech wrote:A few sites to help understand:http://www.edn.com/article/CA56634.html
