480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Aug 05, 2008 6:39 pm
Alright, well ill try to break it down.
A PCV system is really important for a boosted car, any car really. When an engine is running, especially at higher pressures associated with wide open throttle(or when your getting on it, w/e), a small percentage of the gases that are inside the combustion chamber escape past the rings. These gases go into the crank case, and pollute the oil. When you multiply your cylinder pressures by adding boost, more gas will escape your rings.
Most people disable the stock PCV system when they do a Ka-T setup. It is a PITA and causes vac/boost leaks. I have no idea how the stock PCV valve reacts to boost, but it almost certainly will fail under higher levels of boost. In reality, boosting on the stock valve/stock PCV system isnt such a good idea at all. Your asking for a massive boost leak thats going to be really hard to detect, its just going to blow air into your crank case. Like i say though, i have no experience with the stock valve or PCV system under boost, i just understand how its designed.
The stock PCV valve is a tiny one way valve attached to a breather/separator on your your lower timing chain cover. This is all near your water pump intake, below it. Its a little box looking like thing. The PCV valve itself is a fitting on the end of the box, pointing towards the firewall with a hose sticking out of it.
Basically, a PCV setup keeps your oil cleaner, longer. Without a PCV system you would never get 3000 miles out of your oil, especially on a boosted motor. Whats worse, running with polluted oil will smoke your engine in a quickness. Turbo, head, bearings, you name it.
I learned this the hard way on my last build, the one with a blown ECU. On the plus side i found that my PCV setup was working great, my catch can was filled up nearly half way with nothing but black gas, not even oil.
