do i really need a FPR???
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
well my car is running really rich!! i know that for a fact....i mean i have just the basic mods...exhaust255lph walbro
well thats bout it...i mean is it really worth it? and how do i know when it is tuned correctly...
thanks guys!!
T-rev
a high flow walbro and the stock SR's fpr tends to raise the fuel pressure, and make things run on the rich side
I bought a nismo adjustable fpr and dialed it to the stock pressure (43 psi I think) using a gauge
periferal7
Car: 1978 Datsun 210 Wagon w/CA18DET
I WOULD HIGHLY RECOMMEND IT.I bet your over 55psi right now, without the FPR.Get a gauge & FPR.
periferal7
A
periferal7 wrote:I WOULD HIGHLY RECOMMEND IT.I bet your over 55psi right now, without the FPR.Get a gauge & FPR.
and yes it is really worth it.You will be fouling plugs,building up unneccesary carbon on you valves,pistons,etc.I mean running rich isn't all that bad for now,but in the long run it can cost you more than a FPR.
SR20S13
so how do i adjust it once i put it on?? will i gain any mpg's? and will it pick up any power?? thanks!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Probably not that much will be gained back on economy.
FPRs are not power adders. So don't expect power.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
On a related note, which line do you install the fuel pressure gauge along? The line going from the fuel rail to the fuel filter or the line going from the fuel pressure regulator to the hardline?
mistamacadamian
Car: s13
theres a how-to thread on here some where with pics an ****
Hijacker
'94 F-150
positron_ wrote:On a related note, which line do you install the fuel pressure gauge along? The line going from the fuel rail to the fuel filter or the line going from the fuel pressure regulator to the hardline?
You want it on the pressurized line....so before the fuel rail from the filter.
positron1
Thanks!
CMG
Car: 1989 240sx Hatch w/ Redtop
I have Nismo FPR that I've been lagging on putting on. Good thing I read this thread cuz I did not realize it was such an issue.
ryan15
Car: 1990 240sx
I dont understand why people have issues, I run a walbro 255lph fuel pump and I dont run rich, and I get good gas mileage still, also monitered via wideband
