SmokeDaT wrote:So I'm a little pissed right now. I take advantage of the Konig special that Kyle had. I ordered the: KONIG TROUBLE 19X8 5X114.3 ET30 FMGRAPHITE wheels.They finally arrive yesterday, I had to go pick them up at the UPS warehouse. The boxes it came in didn't fit in my car so I had to open the box and load the rims in individually, no problem. I leave the two boxes by the garbage in the parking lot. I get to my place and i see on the box the size says 19x9. I'm like ARE YOU KIDDING ME. My question is will these wheels fit on the 3.5SE coupe with the Eibach kit? The offset is 30 and they are 19x9. Will I be alright or will there be rub? Do I need to call Kyle and express my dissatisfaction and have these returned for the correct set I ordered?
Modified by SmokeDaT at 9:13 AM 7/22/2008
I'm running 20 x 8.5, with +35 offset and 245 tires... your 19 x9 with +30 offset and 245 tires would place you 12mm further out than my current setup... hmm, its a tough call, but if you're running 235 tires, you're onlyabout 9.5 mm further out than my setup... I would say keep em and go for it.. even if you have to roll the fenders, it will be very minimal!
