do I need to relace coil packs when giving my car a tune-up?
cpoage
Car: 1991 infiniti Q45
or can i just do the plugs and call it good?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
If you are not having a running issue I would say that there is no need to replace whats not broken. You can perform a resistance check on the ignition coils if your interested. Are you replacing them for a reason other than maintenance?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Should not be required unlesss a power balance test reveals a problem that follows the coil when it is moved.
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:Should not be required unlesss a power balance test reveals a problem that follows the coil when it is moved.
and....I don't recall any 90-96 owners having problems with coils. The next generation Q (97+) is a different story.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
They are actually pretty few and far between but they do happen. Given the amount of times they have been used over the course of more than a decade of use that they are constantly making and breaking a magnetic field they will wear as all things have a serviceable life. You will know when they start to go if you pay attention to fuel economy and accelerator pedal feel.
cpoage
no problems, just maintenance. TY so much for all the help ^^
