BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Tue Feb 11, 2003 5:34 am
you need your speed sensor from the transmission. I also used my reverse and neutral positioning sensors off the KA transmission. You'll need the one dash plug from your wiring harness. You need to keep your A/C compressor if you don't want/have (SOHC) to modify the hardlines.
Honestly, just keep your KA around, so that you can pull stuff off of it if you need it. On mine, there was a bracket that I pulled off to support my airfilter, and another one to support my oil catch tank. It's not the greatest thing, but if you have a drill, you can make pretty much any support bracket you need.
