do i need to have a blow off valve
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
i didnt put a blow off valve on my car. people has told me its fine without it but i just wanted to make sure if thats healthy for my car or not
Murdered_T
Car: 1979 Datsun 280ZX byach
ummmm.... how are you holding boost? or, how are you not boost spiking?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Moving this to 240 tech.
So long as you have some sort of diverter valve on your turbo system, you'll be fine. The stock setup will have a diverter valve next to the side mount intercooler.
DevilMB3017
Sell me your car.
Or come to my friends shop to get work done.
Either way...
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Holding boost and boost spikes are effects controlled by the wastegate, not the blow off valve. OP yes. You need to run a BOV. Intentionally subjecting your turbo to surge is stupid.
danielsan
Car: 1991 240sx coupe SE
what about older factory turbo cars? my 300zx turbo has no blow off valve, no intercooler just straight pipe from the turbo to tine intake manifold.
redtop91
IIRC some CA18DET's didn't have BOV's. Like Bart said checking for the bypass valve will let you know if you need to run anything aftermarket or not. FWIW the bypass valve tends to be a little leaky in my experience.
0range_Kouki24O
everyone thanks for the replys. i had two friends drop by just now to talk to me about it and my best bet is to just get a blow off valve
Dead Serious
Car: 90 240sx hatch
if u werent running any kind of bov or recirc then with one u should see less turbo lag because surge decreses the turbos rpm between shifts.
0range_Kouki24O
whos your friend and wheres his shop
0range_Kouki24O
any suggestions on a good blow off valve ? gredy type-r or blitz supersound blow off
480sx
Car: 1996 Pearl White 240sx
Either go with Tial or HKS.
The main reason older cars and some new stock turbocharged cars dont have BOV's is because low boost level surge does little to nothing to a turbocharger.
DevilMB3017
Raymond Motor Works, on Raymond Blvd. in Newark.
If you want more information and somewhere to get things done, let me know.
[email protected]
0range_Kouki24O
well im 7psi right now is that safe for my car right now ???
Goldeneagle
Car: 1992 240sx Coupe
Synapse Engineering
Dead Serious
Car: 90 240sx hatch
you get what u pay for......a friend had an rfl that leaked and one had a forge that came with stripped out hardware and wasnt adjustable. i have a second gen hks and it works perfect even after some elemental abuse.
one_white_s14
Car: 98 240sx
hks ssq
