These are easy fixes. Your knock sensor if going bad will throw your timing off making it hard to drive. EGR sensor will f up with your idle.Penguins50 wrote:I took my 96 G20 to the mechanic to diagnose the check engine light. The codes were P0325 - Knock Sensor Circuit and P0400 - EGR System Circuit.
To replace both of these the cost would be ~1800. To take care of only the EGR problem would be ~500.
The car has 120k miles and I estimate is only worth about $1000 so I hesitate to put a lot more money into it. My understanding is that these problems would affect my gas consumption and engine efficiency but I have not noticed any problems while driving or reduced gas mileage. Do I need to get these repairs done? I only drive about 5000 miles a year now.
The mechanic mentioned that if I don't fix it the car could eventually stall. How likely is this and would I risk damaging other parts of the car? Or could I always just get the same things fixed when (if) that happened?
Thanks very much for your replies. I look forward to any comments.
