Do I need to do flywheel resurfacing?
xagna
I'm about to put a new clutch this weekend. The clutch is a 6 puck. This is the model. http://cgi.ebay.com/ebaymotors...05941
Do I need to resurface the flywheel?
LordOfTheMiasma
Car: s-13 hicas sr20det 240sx
usually yes, i have never heard of anyone putting a clutc in without doing so, i could be wrong but it cant hurt.
xagna
where in Bergen Co. NJ can you get your flywheel resurfaced?
180fan
Car: 89 fastback
look for a machine shop.
Red coupe
Car: 92 Nissan 240sx Coupe
180fan wrote:look for a machine shop.
and failing that just contact any shop that would do a clutch for you...as them if they can just resurface the flywheel, if they dont have the equipment odds are they can point you to the guy they goto...
spyro187
Car: 1990 240sx, ka24de swap, gutted rear, 17" motegi's, msd coil, injen intake, electric fan
When I replaced my clutch I just sanded the whole flywheel with fine grit sandpaper. It looked new when I was done and has worked perfectly ever since. It was a stage 1 centerforce.
350gtboi
Find a local NAPA, I'm in Union County, NJ and most napas around here have machine services.
da40
Car: 1995 SE 240sx
for sure!it only costs like 40 bucks at the auto parts store(orielly) its better for the clutch life,and breaks in more eveny
teddy
Car: Saab Turbo and MR2
The only time you wouldn't resurface the flywheel when changing your clutch is if the flywheel is brand new.
