Do I need the 97 240 ka fuel rail + wires when I swap it into my 91 240?
mr_wizard
I REALLY don't want to swap these two. It doesn't look easy in the least, so if I can get away with maybe a check engine light that would be fine I suppose.
My other question is do I have to swap intake manifolds too? What are the consequences if I don't?
At this point, I've spent 2 weeks just disconnecting hoses and taking off bolts and screws from the transmission and motor, and the last thing I want to have to do is another project swapping those two things haha. Thanks all.
180fan
Car: 89 fastback
use the block and head from the 97 and everything else use from your busted 91
mr_wizard
The old motor threw a rod. The crank shaft is probably destroyed and the block I'm sure is damaged from the rod bouncing round in the motor. Piston probably not recoverable either. I need to swap the entire motor over, just need the very minimum from my old motor.
mr_wizard
Anyone? If I don't hear anything I'm just going to swap the entire motor over and not swap anything between the two motors. I don't see any reason not to do so. I don't care if it fails emissions, I just want it to run.
