Is this for the fwd or rwd CA? The starter teeth jammed up on the flywheel ring gear? Why do you think you need a new "coil?" Is it bogging or stumbling at a certain rpm?189k240 wrote:Ok,
the ignitions been spotty, it actually jammed the flywheel and now i have a new started since it got ground up.
How do i know if i need a new ignition OR just the coil? Even with the new starter, turning the key seems like it's going to grind up again.
Help!!!
Chriss
