Do I need an SAFC if I'm using a z32 MAF?
mkory
Car: Mazdaspeed Miata
Okay, I'm going to be running 370cc injectors, and am currently looking into getting an SAFC. Since the SAFC changes the signal from the 240's MAF to match the injectors, would I really need one if I were running a 300zx's MAF? Wouldn't that already give out the correct voltage for the injectors?
Craving4Boost
Car: 91 240sx fastback
your ECU will not know your running a z32 MAF unless you configure the signal from the SAFC...you also need to use the SAFC to set the maps for the fuel....only a tuned ECU like JWT or enthalpy would not require you to get a piggy back
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Short answer: To run bigger injectors OR any different MAF on a stock ECU, you need some piggyback controller, like an S-AFC.
The VOLTAGE CURVE is different...so it's not a matter opf matching MAF + injectors...its a matter of the ECU expecting to see a certain airflow voltage for a given RPM and load...and the Z32 MAF curve is QUITE different than the stock MAF curve.
The S-AFC translates the Z32 curve and makes it "look" like the S13/S14 curve to the ECU.
- Brian
mkory
Okay, so to make 370cc injectors work like stock the SAFC should be set at -27% across the board. What should it be set at with a z32 MAF?
Craving4Boost
you should really just get a wideband and find out..i know people with 370cc's and dont use -27% because all cars are different
mkory
Well, i can't really dish out the money for a wideband just yet. That's one of those down the road things when I upgrade over 7 pounds and tune myself. Even after I get the turbo hooked up and everything, -27% should be just fine enough to make it to get it tuned about an hour away as long as I don't really hit boost.
