Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Feb 05, 2004 5:56 am
Unfortunately changing front camber means changing metal components.......the upper links are the cheapest and easiest to change.
The Q was designed to get aligned at least once per year as minute wear in bushings can throw the thrust angle out........hard to get and keep a perfect 0.00 degrees.
