speedracerlo wrote:I installed a cheap HID kit some time ago and the driver side headlight seems to be slightly flickering. It's not flickering like a strobe, but I can see some kind of vibration from the light and it's not as bright as the passenger side. The color from the flickering light is also not as fully white and has a bit of green tint. I also switched out the bulbs too and it displays the same thing. Has anyone had this kind of problem from an aftermarket HID kit?
The only thing I can imagine is the problem would be the stock headlamp wire not providing enough current to the ballast.
I've switched out the ballast twice, but it also proved to be a waste of money.
I had this problem on my e36 BMW - common on the passenger side as that is a longer run and worse after the rain when the leakage would increase. There are usually three causes to this - you've likely ruled out the bulb. The second to check is the ballast by swapping ballasts across sides and see if the behavior swaps as well. The third is that you aren't able to get enough current for the high draw during ignition. The common solution to this is to put a relay in place - use the existing wiring to engage the relay and run a second lower gauge wire for the actual power - with a fuse in line mind! Everyone has the same wiring and I doubt there is much aging at work here yet. You might be able to clean the contacts and get better ignition. A stupid test for this (that will work) is to run a high current pair from the engine positive and chassis ground to the balast input and see if it fires up cleanly.
One of the issues when you do this on BMW's is that they measure the voltage drop across the bulb to assess whether the bulb is still good and the relay will provide the wrong drop so the car computer announces a "bad bulb" - I don't know if Infinitis have this check or not.
Peter
