Do I need a new plastic cover under engine?
stock1992q45
Car: 2009 NAH Blue / Blonde / Convenience Package
1992 Q
The plastic cover (the one you take off when you change the oil) is damaged in the corner and hangs down a few inches.
Can I go without it? (Car is in So. Cal.)
Anywhere suggestions on where to get one new or used? Infiniti wants over $200.
Thanks for the advice.
Doug
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
They are about $150 from Joe.
And yes you need one to manage under car and engine compartment airlfow. Along with functioning foam battens on either side of the radiator.
Look for a post from Q45tech last weak or so that links to a bunch of online articles. In my post, I link to a study of under engine trays and their affects on drag anad cooling.
Modified by maxnix at 11:44 AM 10/10/2008
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
Have you thought about repairing with fiberglass? I guess it comes to what your time is worth and what the car is worth, and if you like to do repairs.
If it is only slightly damaged, and you have the broken piece it could be repaired. Cosmetics do not matter so much underneath the car.
