mss5413 wrote:what i mean by on and off is when i fix it, it will come back say 2 weeks later and i am tempted to think i have a problem somewhere else. A friend of mine from work was riding with me while my car was bogging out like it is now, and she said that she could smell fuel fumes. Maybe I am still running rich, I don't know. By the way, I am cleaning the sensor on the inside and outside. I am spraying the little internal resistor with carb cleaner and also spraying the connection itself. Is it worth the risk of buying a new sensor, since it did come out of a salvage yard, or does the fact that it came out of a salvage yard have nothing to do with it? Maybe some of you having the same problems can give me some more input. Thanks. I will keep ya'll updated if I find a solution or get any ideas.
Actually, I think the correct way to clean the sensor is to drip carbcleaner/alcohol above it and let it slide down over it - not to spray it directly because it's a sensitive device.
There are so many ways our cars can get rough idling/acc problems it's not even funny.
For my problem, after cleaning the sensors, I also noted that the sensor plug was slightly hitting the hood, so I rotated it a lil so it cleared it.
Another thing you may want to check is removing/plugging/cleaning the aiv (the smaller resonator box that connects to the intake via a smaller tube. You can do a search for aiv removal/cleaning. This usually cures up a lot of the idling problems that come and go. To test it, just plug up both ends temporarily and see if your problem goes away. If it does, that means the aiv is dirty and actually sending exhaust gas into your intake.
Also, have you replaced your spark plugs, wires, dist cab, and rotor lately? Check those to see how they are doing. Just to rule those things out.
Hope that helps some.
