benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Fri Jan 21, 2005 4:42 pm
Yeah. Master cylinder needs to be replaced. Forget the rebuild kit. A rebuilt one should be about the same price. (don't quote me though)
While you're doing the master cylinder, I'd take out the booster and shake it around and listen to see if it is full of fluid. If so- drain it all out, re-install it, see if it works well, then replace it in a few months when the residual fluid finally gets to the seals.
You could go ahead and replace them both now, but with the booster costing around $80 (again- no quoting please) I'd hold off until it actually goes south.
Whatever the case - it's up to you.
