evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Dec 06, 2006 8:55 am
go to autozone and they will hook up and test your charging system fro free, sounds more like an ailing aternator but they can tell you for sure
as for the wastegate actuators, there should be a vac line going from the outermost hard pipe going back to the wastegate actuators, I dunno how the profec works but I assume it simply needs to go inline on that vac line, and without it hooked up you'll be limited to stock boost, assuming the lines are hooked to the actuators, if not then the wastegate will not open and you will run very high boost levels
