2007 Altima 2.5, 205K
Bought car with 165K. Had CVT trouble since 170K approximately. Changed fluid. Kept it to in-town commute,, shorter trips, lower RPMs. Recently changed fluid again. Getting codes P0745, P0840 and P0845 every time. Codes come up even before I put it in drive. TSB suggests changing valve body for P0845 and P0840. Went to the junkyard to get valve body but all the valve bodies and almost all of the transmissions were already gone. The car is not worth a new CVT if the problem is internal but may be worth a valve body. I removed the transmission oil pan and valve body and there was very little debris which was promising.
Appreciate anyone's help.
Thanks,
Richard
