Fla240sx »
https://forums.nicoclub.com/fla240sx-u71754.html
Thu Oct 04, 2007 7:22 am
this picture you see the two vacuum ports, as I call em, I looped together... I just took a piece of old tubing off something else that would fit these two, one is a different size I believe so you really have to squeeze it on.....
here I took a bolt and some tarish type material we use for A/C evaporator boxes to seal it off... use your imagination here, just use something that won't get sucked into the intake manifold.....
This is the port off the intake manifold where I took an old piece of hose and sent it to the FPR... which is located on the backside of the fuel rail... I couldn't get a good quality picture of it.....
in the end pretty much the only thing with vacuum going to it now is the FPR, as you can see... and the big line that runs to the brake booster......
This is the header I bought:
not from this seller but this style, this guy has it for 90 shippedhttp://cgi.ebay.com/ebaymotors...ZWDVW
