simmode1 »
https://forums.nicoclub.com/simmode1-u73804.html
Sun Jan 17, 2010 3:29 pm
Thats very similar to the setup I plan to run next. You're gonna need more than a roll if you wanna run 245/265 stagger on those offsets. But it can be done! I hope you're not afraid of fender pulling and negative camber!
I'm planning this for my next setup:17x9+12 with 235/40/1718x9.5+15 with 255/35/18
I know I'm gonna need to get a little innovative in order to fit that under stock fenders without totally mangling my pristine metal. The primary trick that I'll be using to pull this off is using a tire brand that runs smaller than some other brands but offers superior grip. That, when combined with mild rolling/pulling and mild negative camber, should get the job done.
The same should apply for your proposed setup... add a little more since you intend to run just a bit wider than I plan to.
