Yes i know my head is already finished.I also have a set of OBX camgears but a have to turn both of themto 5deg advanced just to match up the original camgears.Why???kapower06 wrote:im running 270's with 8.8mm of lift.
you will have to have your head milled out near the cam lobes, or else they will hit.
I would recommend getting the cam gears just to do some experimenting with. Then if you can extract any more hp with them, sell them.
Yes. And want to if someone else had the same problem?ks13 wrote:had to advance 5 degrees to "zero" out when referencing next to stock?
OBX baby........
davidcarriage or something on here purchased the OBX units also, wonder if he had the same problem.
Daavid?
