GODCHSR »
https://forums.nicoclub.com/godchsr-u49742.html
Tue Jun 30, 2009 3:37 am
To answer the question: No.But should you for power AND safety purposes: Yes.
You'll have to run less boost and retard the timing a bit for added safety.
Not extracting the heat from the compressed air is counter productive because the idea with turbo charging is to gain a lot of power.
IMO if your plans were to not use an intercooler with the turbo kit then you may as well skip the turbo kit and spend half the money on NO2 and get more power than a non-intercooled kit will get you.
