I found the same with a set I bought, two were definitely tight with the feeler gauge and required a little massaging. I went with .035 IIRC, although my Z guy may have gapped them differently with my build...have to ask him, but I was told by two sources that .035 to .036 is a good range for more than OEM boost.hannman wrote:I just did my plugs and used the Iridiums. They were not all gapped the same. Some were probably as low as 0.025. I think the manual says 0.044" or around 1mm. I think Ash and SZ suggest to gap plugs to around 0.036" if you're running a decent amount of boost.
