goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Thu Jan 17, 2008 2:44 pm
They're only on the passenger side so there's just two- front and rear. Most of the members (not the pie pan guys) have wheels that you can look between the spokes and see the brake pads. I prefer to visually check them myself with a flashlight rather than rely on a dummy light to tell me they're worn. The sensor can be reused with your next set of pads, but once the it wears and activates the warning message it needs to be replaced or jumpered.
Once they are both jumpered you never have to see the "brake pads worn" message but the onus is on you to visually check the pads. When I found out how expensive the sensors were I jumpered them both.
