I have a 2002 infiniti qx4, and ive been doing my research on a particular problem ive been having with this car.
When I press the gas, I will feel an uneasy sway feeling in the rear of the car for a split second. Sometimes at highway speeds it goes on for a while, but in city limits, it only happens the second i press the gas and then stop. When I let go of the gas, I will experience that uneasy feeling again for a split second then back to normal.
Now, questions here...
is this the death sway?
the general info thread thread (
pathfinder-qx4-general-information-and-q-a-t549378.html) claims it's the "lower control arm bushings ", but others state it is the "rear trailing bushings."
Which one is it? Is there a difference between the two?
I read that it could also be the stabilizer links? (see this guy:
i-could-use-some-clarification-on-death ... y#p4853632)
Im just not sure if this is the death sway or not...Thanks!
EDIT:Sorry for bumping this old thread -- My car is still the same, maybe a little worse. I am still not convinced I have the death sway because my issue is basically a sway when I press/depress the gas pedal. Im not sure if its the trailing arm bushings or the stabilizer links.
Anyone have any info on what I have?? I tried yanking the ebreak and looking but I honestly could not tell. Maybe I was not looking in the right place?
