Reno wrote:
basically my car feels like a non vtec honda... thx guys
dang those are some low #'s.Did you open the throttlebody when you did the test?Should be in the 170's.My origional stock engine has 148,000 on it now ,and mine are still 170's across the board.janda240sx wrote:My car kinda does the same thing. My new engine only has 40K on it. You can feel the power all throughout the rpms but once it 4k it feels like it just takes off. My compresion #'s are 160 across all four.
actually I didn't open the throttle and i didn't unhook the injectors. I just removed the plugs. It gives a low number when you do it like that. IF I done the right way it would be about 180 across all.slyedog240sx wrote:dang those are some low #'s.Did you open the throttlebody when you did the test?Should be in the 170's.My origional stock engine has 148,000 on it now ,and mine are still 170's across the board.
Cone Junky wrote:Maybe it was a ka-t before, and the guy removed all the boost goodies before selling it to you.
Although your compression ratio seems perfectly fine, so maybe you have some fuel/spark management problem.
Have you checked your timing? Maybe it is retarded too far...
yea my timing was @ 23 degrees originally now its @ 25... still feels slow... and i did a complete tuneup still... how do i check my spark??/fuel and i blow blue smoke... valve seals??Cone Junky wrote:Maybe it was a ka-t before, and the guy removed all the boost goodies before selling it to you.
Reno wrote:and my friends who have beaten me 1 of the cars compression is 91-92-90-121
