Buzzman wrote:This may or may not help to narrow it down:
Firstly, how many doors have a keyhole?
On my '02, only the drivers' side front door has a keyhole. There isn't one on the passenger side. (I have one on the hatch, but I don't count that one.)
Secondly, try unlocking the doors with the key in the door lock.
Turn it once (clockwise), and the driver's door should unlock.
Turn it clockwise again, and the rest should unlock.
Turning it counterclockwise should lock all four doors.
If yours works that way, then I'm pretty sure you have remote entry.
Hope this helps.
I have three - Driver's Door, Passenger's Door, Hatch Door.
Yes; my locks do work in that fashion.
Towncivilian wrote:There are two different keyfob models, at least for 2001 models; I'm not positive whether 1999.5 models had two. Both have the FCC ID KBRASTU10. The models are MODEL/ A, and MODEL/ 1A I believe. They are not interchangeable. I'm not sure how to determine which one was originally used.
Check if there is a fuse and a relay in the specified positions:
Fuses and relays? Check!
Chuck Tribolet wrote:How sure are you that you have the right fob? That it works?
Well, the posting described it working for any 1999.5-2001 Nissan Pathfinder (with a note pointing out the MODEL/A or MODEL 01/A requirement.)
BUT THEN IF FOUND THIS WEBSITE...
http://www.keylessremotesonline.com/Pathfinder_c249.htm
Which describes the one I purchased (KBRASTU09) as "to be used on the vehicles with the production date after 12/1999".
My production date? - 06/99
Could this be the issue? Any ideas before I make the exchange?
Thanks!
