chickentendah »
https://forums.nicoclub.com/chickentendah-u11049.html
Sun Dec 28, 2003 4:05 pm
Okay after asking people where I should connect a boost gauge vacuum line, I discovered something while testing with lines under the hood.
With the boost gauge T'd off at the wastegate vacuum line (wastegate to stock coldpipe nipple), my boost gauge reports zero psi during idle.
With the boost gauge T'd off at the FPR vacuum line, my boost gauge reports "20" marks below VAC.
Do I have a vacuum leak? Shouldn't both configurations give the same reading since the coldpipe is connected to the intake manifold anyways?
By the way, my redtop wobbles and stutters sporadically during idle. It also wants to stall after revving high and letting off gas during idle.
