Do I have a problem? Altima ECU?
gunSOLVEit
Car: 91' 240sx
Ok...I'm pretty nervous about this, and I did not search this topic, I'm just reaching for the answers that I'm hoping for.
I'm getting ready to send out my CPU to Nistune, and I decide to look up my CPU # just to double check I need the TYPE-3 board.
JA11C33E47 is the code that's on my ECU. Seems as if I need to get the TYPE-4 board?
When I go to http://jimwolftechnology.com/wolfpdf/ECU-ID.PDF It says that this belongs to an 93' ALTIMA (Auto) . Wtf? :confused:
I had bout the car used and he said the motor was not the original, and if I remember correctly he said it was from another S13?
So, is their anything different about the motor itself? Is it possible its just the CPU from an Altima? I'm fairly confused. And How should I go about getting my Nistune set-up?
Has anyone ran into this issue and how did you go about it? Every time I try and call Nistune offices, they're always closed due to our time differences..
Blahh, I hope this is not gonna be a problem..
