how do i go about it?Zwicked wrote:Do a boost leak test. That's the only way to ensure there are no leaks.
*Boost is totally dependent upon load and engine performance. If the engine isn't producing proper power, or it's lagging it will affect the boost it can generate.
i have stock ecu and have done diagnostic test on ecu and showed no codes.Zwicked wrote:It could be a boost leak, bad injector ( I know they are new but Venom has the worst reputation) bad electrical connection, failed o2 etc...etc.
What upgrades do you have such as boost jets or boost controller and ECU upgrade?
If you really want to make sure it's running as good as it can:
1. run ECU diagnostics to make sure nothing obvious has failed.2. pull all electrical connectors and make sure none has corrosion (CAS, PTU, MAF, TPS, AAC, FICD, Air Reg, Injectors, CTS)3. test all of the above components to make sure they are in spec4. what plugs do you have? Stock is best gapped accordingly for mods
like i said im just frustrated thats all...my last few cars included a dohc inline four and a boxer style 4 cylinder which were pretty easy to work on so in comparison its more complex.Zwicked wrote:It's no different then any EFI engine. If all the mechanical end is good (compression, valves, etc) then there isn't much else to go wrong short of boost leak, fuel supply, spark, one of the sensors or control solenoids of which there are only few (CAS, PTU, MAF, TPS, AAC, o2's, Coolant Temp Sensor) that really count. A couple of hours verifying the essentials usually roots out the problem.
