Do I have a blown head gasket??
s10cky
Car: 1992 240sx coupe
hey guys,
recently my 92 coupe started to overheat. i dont know how long I overheated it but when i looked at the guages it was pegge( the temp gauge). So I pulled over.Got it towed home and began to replace the following: thermostat, water pump, cap, and I flushed the radiator. Now the car still runs hot but does not peg out. I did a compression test, it read 150, 150, 150 and 120. There is no coolant in the oil, no bubles in the radiator, and no steam. Could it still be a head gasket or possibly a radiator.
thanks
,matt
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
That one cylinder with 120 psi is a suspect; might be a blown head gasket at that point. Pour a table spoon full of oil down the spark plug hole and rerun the compression test on that cylinder. If the compression doesn't come up, then it's most likely a blown gasket.
It's also possible for the radiator to be plugged up.
s10cky
thanks, i was told that a few days ago, gonna do the test tommorow. thanks alot.
