Do expensive brake pads last signficantly longer than cheap pads?
vancouverbc
Car: 1991 240sx
this auto parts guy told me the cheap ones last 3 months vs 3 yrs for expensive ones. i think he was just going by the warranty?
MoldyOldy240
Car: 1991 240sx 295K w/ original engine.
I have yet to notice a REAL difference in deterioration time.
boznuttz
Car: MS13
The longevity of your pads depends on your driving style, how hard you use them, and what kind of material they are.
Many pads have different temperatures in which they are more efficient. A higher performance pad may not fade as much at higher temperatures and provide less dust. Pads you get as oem replacements may fade very quickly and dust when they reach a certain temperature.
As I said before, it really depends on your driving style.
If you drive hard with a pad that is efficient at lower temperatures, then it won't last as long as a pad with a higher temperature efficiency.
Zippy69
Car: 1993 240sx coupe
I found only marginal longevity in the higher priced pads from places like autozone and advance, but high quality ones from top names do last longer, but I really don't think it's worth it for an aggressive driver. Maybe Granny will get 2-3 years from a set of pads, but I never will.Bottom line....................Buy quality for safety's sake, but don't spend a fortune on brake pads that you are going to replace in about 4-6 months.
vancouverbc
Car: 1991 240sx
Interesting. How many miles should pads last for normal driving?
Rex
Car: None
Assuming by expensive he means better "performance" or softer brake pads, they last significantly less.
NOTE: I moved this to the correct sub-forum, please do not make double posts.
