I hadn't seen any aftermarket knuckles for the s-chassis stateside. There's a few weld-in adaptor kits in japan.... got any links to aftermarket spindles?yokota180sx wrote:yeah when you lower your car alot, the angle from the Knuckle to the tie rod is increased, thus puting more stress on the joint.
there are a few ways to fix thisone, chenge the knuckle to one by a different company, there are 7 or 8 places
ask and you shall recievefrom this months doriten (drift tengoku for others)freshly scanned for you mr Ace!AceInhole wrote:I hadn't seen any aftermarket knuckles for the s-chassis stateside. There's a few weld-in adaptor kits in japan.... got any links to aftermarket spindles?
I'd be wary of doing so on a street car, as every kit I've seen comes with open faced rod-ends. At the very least, use decent quality heims and full boots, and I'd honestly recommend doing a grease fill regardless of what type of rod end you use, as the grease itself acts as both a lubricant and internal barrier.
I think the simplest solution would be: don't over-lower your car.
but yes, of course!always use a boot ad tons of grease if you can. if not, just have a spare set laying aroundAceInhole wrote:
oh sh1t! those are doope... where and how much yo?yokota180sx wrote:
dam.. I'm at work and photobucket is blocked... I cant see any of the dam pix your posting dude, and its killing me, lol94_240sx wrote:I think what yokota posted are modified stock knuckels just like this one. I could be wrong though. If you can get this little piece, you can weld it on, grind and powder coat it. There are 1 and 2-hole versions.
On the other hand, this knuckle is made from scratch.
Yea it looks like all the knuckles are just modified stock knuckles, besides the ones made from welded bar stock. The rears look pretty easy to do, but I'd wonder what they used for the axle up front. I've always wondered how much it'd cost to set up the casting for custom knuckles. I talked to Mark Daddio (driver of the AMS time attack Evo) about it once and supposedly there was a company that could laser scan stuff into CAD, modify it slightly, and remake it in titanium. I'm not sure if he ever actually went through with it, though.yokota180sx wrote:the knuckles are probobally just modified by the company, but still, they are aftermarket optionsthe HEY MAN knuckles i can get, they are made by a guy named SHinji, a d1 driver that has a shop by wher ei live at.
