You just can't go wrong with a nice full JWT valvetrainHijacker wrote:Nissan didn't use any special parts for the intake valves, so they're all identical AFAIK. The intake valves are just fine IMO, but if you're looking for upgraded parts consider checking out what Jim Wolf Technologies has to offer. They have bronze valve guides available for a very fair price. $50 per set IIRC. They also have everything you can possibly want for your valve train as well.
I didn't know that. I was basing what I said off the fact that the cylinder heads themselves are different in length. I think the FWD head is a little bit shorter. We tried placing a FWD head on a RWD block a few years ago for sh1ts and giggles, and I remember the physical dimensions just not lining up.codyace wrote:FWIW: Not sure if all are, but JWT Cams are actually interchangeable between the two. Difference being the length of the pin at the end of the exhaust cam...however the FWD pin also works..
VVL Is off a 'teeny' little bit too to RWD as well....not that we needed to know that, but always good to have in the back of our brains haha.Hijacker wrote: We tried placing a FWD head on a RWD block a few years ago for sh1ts and giggles, and I remember the physical dimensions just not lining up.
Not sure on exact stock DET cams now, but I do know FWD off the top of my head...I'll edit and get the turbo ones on here tooHijacker wrote: One thing to consider though, is that the turbo RWD motor should have a different cam grind than the FWD NA cousin. Can't confirm that, but I would be stunned to find that the OE grinds were the same.
