521ofdoom »
https://forums.nicoclub.com/521ofdoom-u110410.html
Sun Nov 15, 2009 8:34 pm
Lowering by adjusting the torsion bars in cake in the front, they have a pretty linear rate, so, as long as you keep it off the bumpstops, the spring rate will stay the same, no matter the ride height. in the rear, a set of lowering blocks simply moves the axle, again, no change in spring rate. Same ride. Make sure to have your alignment checked after lowering it, may not need adjustment. I have had good luck with pulling my bars out, moving them one spline lower and re-tensioning them. gives a 1.5" drop or so. and they're still at full tension. Good luck
