do 300ZX breaks work with ALL 17's??
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
i know you need to get 17's in order to be able to do the 300zx break conversion, but i wanna know it every 17inch rim will work. i know that some of the 17's and 18's out there barely leave enough room for the caliper. i wouldn't wanna buy expensive rims and not be able to do the swap cause the rims weren't shaped right. that would stink.
ennui
Car: Cars, computers & snowboarding
95silviase wrote:i know you need to get 17's in order to be able to do the 300zx break conversion, but i wanna know it every 17inch rim will work. i know that some of the 17's and 18's out there barely leave enough room for the caliper. i wouldn't wanna buy expensive rims and not be able to do the swap cause the rims weren't shaped right. that would stink.
Say what? I thought I read on the old forums you could do the 26mm 300ZX brake swap with stock 15" wheels+hubcaps? I thought it was only for the 30mm rotors that you needed to look into swapping your rims . . . and wouldn't that be a matter of offset and not diameter?
I H8 UR DSM
ennui, you are correct..offset not diameter. you can use any size rims, just need the proper offset.
dankar
Car: racing, grandkids
15" wheels (the spoke wheels, not the teardrop wheels) will fit with the 300z brakes with a 1/4 spacer or you can grind a little bit off the spoke wheels. We have done both and used them on autoX and track events with no problems. You just have to use a good judgment on how much to grind, it isnt that big a deal.I know all the wheel dealers will have a fit over this, but all I can say, we made it work and never had a failure and we ran a lot of laps.
UncleBen
i found out that all 300zx brakes will work with the 1995 240sx SE 16" rims. even some of the skyline's will apparently. i can't remember what the diameter of them were, but they said they would with no problem.
