I'm not so sure what you are saying about the Jics...but I think you should read this (from SCC speaking about the S13):The biggest problem with Nissan suspensions of this era is limited compression travel. Lower any Sentra, Maxima or 240SX from the '90s and you'll get to know the bump stops. To work properly, a 240SX suspension will either have to sit at nearly the stock ride height, or have shorter shock bodies that allow more compression travel. The problem with shortened shock bodies, however, is the amount of compression travel you can actually use depends on the size of your tires. Suspension travel is useless if the tires just bottom out in the wheelwells.
This is where the JIC suspension stands out. In addition to a threaded spring perch that allows you to adjust ride height, the lower shock mount is also threaded, so you can adjust the position of the shock body. This allows you to position the shock so the bump stop stops the wheel just before the tire bottoms out, maximizing travel no matter what size tire you have
The DMS only have an adjustable spring perch, so lowering the car reduces suspension travel and gives adverse effects to the cars performance/drivability.
You seem to think that the ability to adjust height is not important. First off, when you recieve any of these coilovers, there is no factory settings. You asseble the strut. The instructions will give you a general idea of where to set them, but really it's all in how you set them. Second, if you are serious about road racing, you will want your car pretty low to the ground for 2 main reasons...lower center of gravity and less lift. Third, (again, if you are serious about racing) you will want to get your car corner balanced (which employs adjusting the height of the struts to balance the car). If you also buy adjustable suspension components (like battle version or Jic), you won't really have to worry about suspension geometry.
Also, about your valving comment; no, all valves are not created equal. There is different types of valving available from different strut manufacturers...the Jics employ a mono-tube design. What does the DMS have? Probably the same...but the main problem is how they are valved. What I mean is that struts are valved for certain conditions...Dms's are valved for street, rally/tarmac, or rally/gravel, you get to choose. Notice though that none of those are for the Track. Jic's FLTA2's are specifically designed with someone like you in mind. Someone who wants to build a steet car that can run at a racetrack. Who knows though...this is all just speculation anyway. Good luck either way.
