dmax s14 corner lights? fittment?
i4jdm
Car: 1995 240sx (s14) kouki conversion
so i got the dmax kouki corners from frsport and they do not seem to fit. not sure wat to do so can anyone shine light on the situation
BrianHarte
Car: 180sx
Do you have OEM metal fenders?
i4jdm
yea i do
BrianHarte
Car: 180sx
Well, I don't think anybody will be able to point you in the right direction with the limited info you provided.
What does it mean when you say "they don't fit"?
i4jdm
well it goes into the retaning bracket of the headlight but goes in too far of the fender....like its missing a little seal that goes around where it contacts the fender.....does that make any sence? sry im not too good at explanations
initial_jc
Car: KOUKI
i had posted something similar to this
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Uhh... yes there is supposed to be a foam rubber seal that attaches to the edge of the top half of the light. If it didn't come with one (should) then just take the one off the stock light and put it on the Dmax and/or just slightly bend the little metal tab on the fender out to push the rear of the light out... problem solved
i4jdm
its worth a try thanks
i4jdm
Salem240 wrote:Uhh... yes there is supposed to be a foam rubber seal that attaches to the edge of the top half of the light. If it didn't come with one (should) then just take the one off the stock light and put it on the Dmax and/or just slightly bend the little metal tab on the fender out to push the rear of the light out... problem solved
you where right salem it was missing that foam i glued them from my oem ones and they fit now.....they look hella good exept i didnt do such a good job putting the passenger side seal on to well so it looks a little bent but hardly noticable in the dark....lol
