AzureCoupe0888 wrote:find any of the missing cords yet? I wanna fix my kickplate...NEED PICS!!
Sorry Azure, haven't been able to find the USB cords
How to seal Doc Feelgood's kickplates and make em look even sexier:
You will need:-Permatex 81158 #16B Black Silicone Adhesive Sealant-Tube of super glue-Razorblade-Toothpicks or skewers-Old newspaper or papertowels
1) Use the razorblade to remove the excess silicone and slowly pry up the plexiglass/carbon fiber top off of the plastic kickplate base.
2) Remove any and all excess silicone by rubbing your fingers over it (it will rub right off).
3) Lay down old newspaper or towel so you do not get the silicone or super glue on anything you don't want it on.
4) If the colored light is not completely sealed to the plastic base plate, use the super glue (underneath only-- do not get any on top of the colored lightstrip). Careful you do not over do the super glue!
5) Allow that to sit for a few minutes.
6) Take Permatex 16B Black Silicone Sealant and begin to carefully fill the black plastic kickplate base edge gap. Do one entire length at a time. This is so it does not set too quickly.
7) Take your toothpicks (I used a skewer) and use it to ensure there are no airbubbles and that the silicone creates a nice seal in the gap. (I filled mine to the top so it was level with the surface. Wipe off excess silicone on the newspaper or papertowel and continue to ensure a solid seal along that side.
8) Repeat steps 6 and 7 for the other side as well as the edges.
9) Allow to sit for about 5-10 minutes.
10) Squirt a strip/blob of the Permatex 16B Silicon along the center of the plastic base of the kickplates, without getting too close to the colored lightstrip.
11) Firmly place the plexiglass/carbon fiber top down onto the kickplate plastic base and center it as necessary. Use a napkin, papertowel, or finger to remove excess silicone.
12) Use vices, textbooks, or in my case-- soupcans on the back of the kickplates to apply pressure. If you are using a vice-- be very careful not to tighten too much. Soupcans worked great as it was the right amount of pressure on the back of the kickplates to allow the silicone to completely set.
13) Allow to sit for 12-24 hours. You are then good to go. Touch up the edges of the kickplates with silicone if you missed any spots.
